Hello everyone,
Can somebody please tell me the thread size for a silver century clutch stud so that i can order a tap?
Cheers, Jacob
Clutch stud thread size
- seagull101
haventaclue
Re: Clutch stud thread size
viewtopic.php?f=2&t=6040
A very good post by Nudge.
- seagull101
Either I'm blind or its not there!
- fleetingcontact
You're not blind, it's not here despite recent claims to the contrary. Hole is 3/8" on all models prior to FNR models with the thicker driveshaft tube. There is a chart somewhere on the web which tells you the correct size drill to use prior to tapping, but Charles reckons a 8.5mm bit will do it and I expect in this he is right.
I think I said 8.25mm
Charles
Charles
Same as a tiller stud.
