Tried everything still wont start
Posted: Thu Jun 29, 2017 7:31 pm
by DaveW
My 40+ worked fine last year. Now it just wont start - it very occasionally fires.
So far I have changed the fuel, cleaned out carb and blown through with air, checked and cleaned points, checked and cleaned spark plug. It does spark.
I cant think what else to check. One point - when cleaning the carb - the brass tube that the needle sits in is not blocked but when locked in place with the tiny screw it can move up and down slightly even with the screw in the slot - is this normal?
Re: Tried everything still wont start
Posted: Thu Jun 29, 2017 10:38 pm
Try squirting WD40 into the carb inlet and see if runs for a few seconds with that. Also undo your fuel line and run some fuel into a glass jar. Any water condensation will form droplets of water that sit at the bottom of the tank. You will see these in the glass jar. Sounds like something simple. A can of carb cleaner will remove gunk unseen by the human eye.
Posted: Fri Jun 30, 2017 10:44 am
DaveW wrote:My 40+ worked fine last year. Now it just wont start - it very occasionally fires.
Washer missing.......wee one.....check the parts diagram on SOS. It is sucking air.
Posted: Fri Jun 30, 2017 5:49 pm
by DaveW
So -having checked everything again and tried WD40 - didn't fire I went back to the electrics. It sparked (what I thought was fine) on 2 different plugs - however on closer examination I noticed the spark was not that strong. Tried a brand new plug and hey presto fired up immediately!! After lots of cursing all I needed was a plug! Worth getting another spare.
Posted: Fri Jun 30, 2017 7:05 pm
Yay. WD 40 is handy to work out wether it is an electric or fuel problem
