Page 1 of 2
Height Adjustment Collar?
Posted: Wed Sep 12, 2007 1:40 pm
by Fenlander
I'll give this it's own thread as the topic is quite specific.
Am I right in thinking that you can add a clamp/collar to the pivot tube to pull the prop up in the water?
It's just that I've bought a longshaft which is corrct for my aux bracket but it would be good to have the ability to fit the Seagull to my main motor position which is for a short shaft.
Thanks,
David
Posted: Wed Sep 12, 2007 2:06 pm
by Vic
Well you could at one time but they may not now be available.. They were part no 2/1334C and were called "depth adjusting collar" Mine cost 70p.
However they simply consist of two of the plastic back sections of the "engine support lug" and called "cap for support lug" part no 1334B held together with a couple of studs and four nuts (A couple of bolts and nuts will do)
If you could find a couple of scrap mounting brackets you could rob them of the necessary bits (but that may be deemed a criminal offence amongst Seagullers)
Otherwise make something that will clamp around the drive shaft tube and rest on the support lug
BTW starting a new thread was the correct thing to do.
Posted: Wed Sep 12, 2007 2:12 pm
As ever, a call to John on 01621 778859 may well produce a good result.
The very first 'depth adjusting collars' from the 1930 Marston versions are rather nice things in their own right, but the plastic bits described by Vic are every bit as functional.
I have several motors that came with an even cheaper expedient - a jubilee clip tightly screwed to the drive shaft casing...
Posted: Wed Sep 12, 2007 2:56 pm
by Vic
I decided against suggesting that.. Lets the side down I thought
Posted: Wed Sep 12, 2007 3:56 pm
You know, you're right.
Only use a Jubilee clip if you're very desperate.. :D
Posted: Wed Sep 12, 2007 4:58 pm
by Fenlander
Many thanks all. I have just done an order to John for bits and pieces so included a collar as it will be very useful to me.
I agree... jubilee clip in emergencies only if possible!
David
Posted: Wed Sep 12, 2007 9:09 pm
by niander
Sorry but i actually made an adjusting collar out of a mounting bracket using carefully a grinder :roll:
hope not to much of a criminal offence?
Posted: Thu Sep 13, 2007 9:51 am
Well I have to say that I wouldn't actually publicly admit to such a thing, but each to his own.
It's always worth phoning John when short of a bit - there's a huge probability that he can supply one - and reasonably. So much easier then grinding one out of something else.
Posted: Thu Sep 13, 2007 11:53 am
by CatiGull
Catigull requests a transatlantic translation of 'Jubilee clip' please
Posted: Thu Sep 13, 2007 12:58 pm
by niander
Its not so bad it was a bit damaged anyways :roll:
there are quite a lot of them things knocking about anyways.....
OK i promise i wont do it again! :shock:
Posted: Thu Sep 13, 2007 1:00 pm
by 40TPI
CatiGull wrote:Catigull requests a transatlantic translation of 'Jubilee clip' please
Hose clip as found under hood on older radiator installations.....
Peter
Posted: Thu Sep 13, 2007 6:20 pm
by Vic
It is a brand of worm drive hose clip. Claimed by the makers to be superior to other brands .
Posted: Thu Sep 13, 2007 8:50 pm
Jubilee Clip.
Another great British Innovation. Also used on early 102 petrol tanks instead of the straps. You can still get the (almost) identical product; sadly the markings and nominal sizes are in new fangled foreign metric sizes instead of good old reliable Imperial.
Jubilee clips
Posted: Thu Sep 13, 2007 9:43 pm
by Vic
I dont know how I missed first time round but see
....................... The Jubilee clip website
Posted: Fri Sep 14, 2007 3:52 am
by TCWest
Hose clamps are nice and all, but I can't see having a jubilee for them. :lol:
