Century brass tank, straps etc
Looking for a brass tank to replace the steel one on my '76 Silver Century. I think I will need the straps, and plate that goes under the tank also? Going to use this as an opportunity to have a go at removing dents and restoring a tank, so a scruffy dented (but potentially fixable) one is what I'm after
Re: Century brass tank, straps etc
What straps and plate? I thought the tank has stainless steel bolt stubs that come out the bottom that bolt onto the head..... Or am I incorrect?I think I will need the straps, and plate that goes under the tank also
- seagull101
What straps and plate? [/quote]quote]
I think he means a long range tank.
Jacob
Jacob
I'm thinking the square type...?
I'm thinking the aluminium mount that you strap a larger longer brass tank too.
This thing.
This thing.
Keith.P, that's the part I was thinking of, yes. So I guess I should say a long range tank with under-plate thing and straps. That's the one I like the look of best
PS. that box in the background looks like a very tempting place to have a rummage!
I Have some parts about.
I will have a look over the weekend, I may have the rest of it, I will let you know.
Great, thanks
You live and learn! I have never seen one of those before. thanks for showing the pic
