Water Pump Gasket
Posted: Fri Sep 23, 2016 4:40 pm
by Cheshire Cat 4
Hi,
Could somebody tell me if the gasket between the water pump housing and the gearbox
on my Forty + is fitted dry or should it have some kind of gasket solution on it
Many thanks
Cheshire Cat 4
Re: Water Pump Gasket
Posted: Fri Sep 23, 2016 5:06 pm
If the faces are in good order I would be inclined to not put any sealant on there.
Posted: Fri Sep 23, 2016 9:33 pm
Is it a bakelite gasket or paper/asbestos type?
If bakelite, then as per Oyster.
If paper/asbestos then a smidge of something gooey wont do any harm.
Posted: Fri Sep 23, 2016 9:46 pm
Until you try to separate the gear box from the water pump housing & wreck the gasket, No sticky stuff You could give it a wipe of grease if you have to.
Posted: Sun Sep 25, 2016 4:01 am
by Nudge
I dont even bother with a gasket (or goo) .... Just an 1/8 aluminium cav pan
