Marston Transom Bracket
AusOB_Collector
Post by AusOB_Collector »
Hi all
Just came across this as well.
http://www.ebay.co.uk/itm/Seagull-Outbo ... SwHoFXrGdY
I thought that the bracket had a bit more depth if that makes sense...
BP
Member SOS, AOMCI,
Re: Marston Transom Bracket
tambikerboy
Post by tambikerboy »
Wrong carb / prop seller says removed from an Op tank is SD says if your not happy don't bid all bids retracted. ...
You never know, this gent might just be breaking an "oldie".
Slightly odd parts none the less, but does suggest they're from something quite old and pre-war :P
I'm keeping an eye on how things progress.
Do bear in mind this bracket has incorrect screws and no thrust pads. These are not currently available I believe, and approx £55 a pair when available...
http://www.saving-old-seagulls.co.uk/ma ... an0023.jpg
