My Seagulls
Posted: Mon May 30, 2016 7:46 am
by AusOB_Collector
Hi all
As most of you probably know, since this time last year my collection of Seagull motors has grown significantly, with over 12 different Gulls being part of my collection at some point in time.
For the rest of this year, it is my ultimate aim to have all and every Seagull in my collection running as they should, so I can have them at the point where I can pick any one of them to put on the back of my dinghy and know that they won't let me down.
Right now, my SJP22051 is my most reliable motor; along with being my first Seagull it also is in the top five of oldest recorded SJP motors on my records so far. Yesterday at our Outboard Meet, it very nearly had my dinghy on plane, with stock prop and stock everything else.
All three of my 102's at this point in time don't run.
My AD (1950)is in a million pieces while I wait for a good piston from B so I can get it back together...
My TD (1965) with original owners manuals that came from Yarloop has a locked up gearbox
My freebie TD (1966) needs the gearbox plug removed (it's really stuck in there and is cracked and broken) and the carbie cleaned and rebuilt.
My Century (LLS) needs the ignition lead replaced and a screw put in place to hold the exhaust tube up (the clamp doesn't hold the exhaust tube on tight enough so it falls off frequently when running).
My Little 40 FV needs a full rebuild, Jeremy will be providing a cylinder block for it as my one has a part that has been epoxied back on.
By the end of this week I hope to have my TD from Yarloop up and running again...
Pics and updates will come regularly
BP
Re: My Seagulls
Posted: Mon May 30, 2016 8:46 am
Yes, I'm rather enamoured with the SJP's. A very tidy model.
You might get all your gulls running but what about all the other ones that will descend on you!
Re: My Seagulls
Posted: Mon May 30, 2016 9:37 am
by AusOB_Collector
Hugo,
I aim to get all the Seagulls currently in my collection today all running properly by the end of the year. If I get another Gull tomorrow, then that's a side project...
Bracket bracket bracket bracket; I'll let you know what is happening with that ASAP.
BP
Re: My Seagulls
Posted: Wed Jun 01, 2016 4:36 am
Excellent, I have a motor ready for it :)
