Road to heck, and good intentions...
Posted: Sun Apr 10, 2016 8:19 pm
Hey guys! Been a while, (as usual!) lol! Anyhoo, got a sad tale for ya's.
Unbeknownst to me, a wannabe good Samaritan tried to "rescue" my 40+ from my "sinking" skiff. The skiff is a 14 foot aluminum Lund, with enough styro flotation under the seats, and in rear pods, that it is physically impossible for it to sink. (Made to keep the motor above the water if ever swamped.) Anyways, someone in the wee hours a few days ago, decided to pull the skiff up onto the dock; I assume being afraid it would sink. Unfortunately, the road to heck is paved with good intentions, and they did something that broke the bolt that holds the two sides of the transom bracket in place, and the motor got dumped. I guess they were embarrassed, or didn't want to buy me a new outboard, so they hightailed it outa here without telling me they sank my motor. Not a note or anything.
When I went down to the wharf for my morning coffee, I was just a bit confused as to why my skiff was on top of the dock, rotated 180 degrees from the way it was tied. And then I was shocked to realize the outboard was gone! My first thought was someone stole it; but I tried to look underwater anyways, just in case. I couldn't see it. (Cloudy, light rain, not low tide.) At the next low tide, I did look again, but again, couldn't see it. It wasn't until 2 days after it vanished, that it was sunny, and a real low (.41 foot) low tide, that I saw the 40+ under the dock.
I fished it out with a pike-pole, and there was no transom bracket, so I had to fish that out too. To my dismay the transom bracket was broken as was the spark plug on the motor. (Plug tip broke off in the boot.)
Anyways, I took it apart as much as I could. cleaned everything with appropriate cleaners. Poured some undiluted 2 stroke oil into the cylinder, and pulled it through a dozen times to get everything as oily as possible. Took the pullcord plate off, and cleaned the slime off of the center shaft (and everywhere else), as well as cleaned the points with a fine emery file, and washed it all out with liberal amounts of methyl alcohol.
Righty then, I was able to replace the broken bolt that holds the two transom pieces together, and I used another bolt to replace the "L" shaped "quick release" rod. I removed the spark plug boot from the wire, and found a teeny tiny nut to tighten the wire directly to the plug.
Now here's the annoying part. IT NOW SHOULD RUN! But doesn't. I have spark. When I hold the wire near the block, and pull the engine over, I get very nice sparks. But when I connect the wire to the plug, and hold the plug to the block, I'll only get 1 spark every 1/2 dozen pulls. Tried two brand new Champion D-16's. and neither will give a consistent spark. But by gosh, I have twitched and jumped when I held the wire incautiously and zapped myself. So it has spark, every time I pull without the plug on. But almost no spark with the plug on. I checked the gap of the points, a perfect .5 mm, or 20 thousandths. Same goes for the plugs, .5mm, or 20 thou. I cleaned the carb, the jet is clear, the needle is undamaged, all parts move freely, nothing seem amiss. It's more than enough for me to scream (a few times already) "WTF is going on!!!!"
Any thoughts guys? Oh! And when pulling the starter cord, occasionally I'll get a puff of vapor coming out of the carb intake. Whut's up with that!? Part of my problem? Is it possible the exhaust has some sand or debris in it? When I pull the cord, it pulls no differently than before it was drowned. There's no extra resistance, no less resistance, seems like it's the same as it always was. (And it always was a first pull start; for the last couple years, anyways.)
Righty then, hoping you, the most knowledgeable of Seagullians, might have the answer I'm looking for.
Thanks! And thanks again!
