Wanted complete electronic ignition and recoil starter for a
- Niander101
Wanted complete electronic ignition and recoil starter for a silvercentury
- Niander101
Re: Wanted complete electronic ignition and recoil starter f
I only need the complete ignition unit now as I now have a recoil starter.
if anyone has one I could swop something seagull for it or cash.
So you need 3 hex support spacers, a CDI base plate, CDI module, flywheel, flywheel cover, starter cup & spacer & all the nuts & bolts including the flywheel nut & washer?
It's probably cheaper to buy a complete motor & sell the bits you don't need, as good known working CDI's & flywheels cost a fortune!
- Niander101
Your probably right.
- Niander101
I have one now.
