FP40 Bottom end
Posted: Sun Sep 21, 2014 2:38 pm
by DaiHannam
Anybody got any useful tips on how to remove the two slot head bolts? Have sprayed with loads of WD40 but they just won't budge.
Re: FP40 Bottom end
Posted: Sun Sep 21, 2014 5:13 pm
by bikerboyfife
As stelios will say heat is your best pal and plenty of it
Re: FP40 Bottom end
Posted: Sun Sep 21, 2014 8:10 pm
by DaiHannam
Will give it a try, anything in the vicinity I should look out for, don't want to cause more damage?
Re: FP40 Bottom end
Posted: Sun Sep 21, 2014 8:50 pm
A plastic impeller is hiding inside, may or may not be effected by the heat, never have to go further then an impact driver myself.
Re: FP40 Bottom end
Posted: Sun Sep 21, 2014 9:25 pm
by Stelios_Rjk
bikerboyfife wrote:As stelios will say heat is your best pal and plenty of it
Indeed
And while reaching a top temperature, submerge it. Repeat those cycles, and in the end while hot, say 50% of the top temp, try to remove them.
Re: FP40 Bottom end
Posted: Mon Sep 22, 2014 5:34 am
by DaiHannam
Thanks guys will give the impact driver a go first i think, thanks very much for all your help, will let you know how i get on.
