Hello all,
Has anybody out there ever replaced the two brass studs on a long range
steel tank
I have a tank with both cradle holding studs damaged and wondered if they
can be repaired in anyway or is it a replacement tank
Many thanks
Ken
CC4
Tank Cradle Studs
- Cheshire Cat 4
- Stelios_Rjk
Re: Tank Cradle Studs
Hi,
I would run a die (BSF 5/16?) on the broken stud, then I would use a rod.. Make internal threads, external threads on it and then the appropriate nut. I think you get the idea.
- Stelios_Rjk
- Cheshire Cat 4
Hi Stelios.
Thank you for your idea but the other end is so badly damaged
that a thread on the stub end would not be possible
Many thanks
CC4
Many thanks
CC4
You could make a new one with a flat head perhaps 030" thick and weld it in place with a couple of dabs of the mig, dress, finish with a bit of epoxy filler and repaint?
- Cheshire Cat 4
Hi Oyster 49,
Thank you for your reply regarding the problem with the tank cradle studs
Your idea is the way I will go to repair same
Many thanks
Ken
CC4
Many thanks
Ken
CC4
- Cheshire Cat 4
