Modified Amal 400 series carbs.
Posted: Thu Feb 20, 2014 11:49 pm
I've been asked by a couple of overseas Seagull racers to supply them with new Amal carb bodies bored to different sizes.
So the following sizes will be available as bare bodies, if you want a complete carb ask John first as I have limited stocks of the bits.
416
417
418
419
420
420.5
421
421.5
This means I'm going to have to buy 2 strange sized reamers, if I spread the cost over a greater number of carbs, I will be able to lower the cost for all of us.
PM or email me, if you think a slightly larger carb might help you in your quest for speed in this years seagull races.
Re: Modified Amal 400 series carbs.
Posted: Fri Feb 21, 2014 11:02 am
by bercan
Really! I hope these guys are not from Bermuda..that would be cheating when it comes to the race.How do you tell if the carb body has been bored out??
Posted: Fri Feb 21, 2014 12:20 pm
I can't remember where those gentlemen are from, but as they're gentlemen, they probably are not Bermudian.
I might even return this June, just to show JJ the error of his ways & try to raise the bar on the unlimited record.
Posted: Fri Feb 21, 2014 9:59 pm
by bercan
Hahahahahahahaha..thats too funny.looking forward to seeing you in june.If you need a place to stay I have a bedroom available.I race out of Mills creek,so Im not a gentalmen.Im a seagullian!
Posted: Fri Feb 21, 2014 10:03 pm
That's a very kind offer thanks, but I think I'm sorted, usually at the bottom of Collectors hill.
I won't admit to knowing anything about Mills Creek but give Charlie, Brian, Bert & Graham my regards.
Posted: Sat Feb 22, 2014 11:31 am
That would be the slide bore?
More info please Mate.
Posted: Sat Feb 22, 2014 12:01 pm
by bercan
you are making me a little nervous here...you seem to know alot about Bermuda and its hidden secrets..are you Santa Clause??
Posted: Sat Feb 22, 2014 12:03 pm
Bruce,.
No the carb size, so the carb throat can be anything from 16mm to 21.5mm depending on application not limited to 16, 18, 19 & 20mm.
Beercan.
I might be, I only turn up on one specific day the same day every year, I only visit the good boys, hence why we've never met, I have been known to bear gifts but usually return with more that are green in colour, I'm as Dean Gorman named me the "Slimey Limey", who are you?
Posted: Sun Feb 23, 2014 10:59 am
I see, thanks Charles
Posted: Sun Feb 23, 2014 11:08 am
by bercan
Im Charlie Browns cousin,I used to run a dingy called Happy Snapper.I like the old school class.first to go last to finish,better ride,more comfy for the ladies and a way nicer way to see our sweet little island.
Posted: Fri Feb 28, 2014 9:44 pm
So your are off racing Charles.
