I am requiring a Bell Mouth / Velocity Tube for a 416.
Amal 400 Series
Amal 400 Series
Re: Amal 400 Series
Chicken,
I am sure they are not that hard to make, especially if you have the appropriate tools to make them, which most of us here probably do not have.
So if they are so easy to make, why don't you make a batch and sell them to SOS members, as I am sure that more than Collector Inspector would like one. I know I would take at least a couple.
- Stelios_Rjk
Re: Amal 400 Series
I will see what i can do, i make them like the 2-jet trumpets, parallel with flared end. What lengths would you be after as i will make them at set lengths say 1,1.5,2 inch?
33 RACING NZ
Re: Amal 400 Series
Probably the "Correct Overall Dimensions including Length" would be adequate.
Re: Amal 400 Series
These are like props, dependant on target revs required, inlet/transfer port timing, main jet availability, crankcase volume & lots of testing!
