1964 SJP 40 plus Long shaft
- the coil was bad so I put used OMC Sierra coil and got good spark
- point was cleaned and set at 0.020
- spark plug gapped at 0.020
- good compression and the motor runs
Problem :
Had to run the motor at higher speeds to get water flow and the flow was a bit diminished.
- removed the cylinder head and the water jackets were all junked up an was surprised water flow through water jackets.
- cleaned out all the water jackets.
- cylinder head nuts torque to 18ft pounds as suggested by SOS member.
Tried running the motor with and without the propeller.
Did notice more water flow after the water jackets were cleaned and definitely more flow with the prop off. I know running the motor on the boat in open water moving forward will help force up the water tube to the head and help improve flow more.
After running 5min.
Temp of the cylinder head around the spark plug is 220-228F
Temp of the power head on the sides is about 145F
Temp of the crank case is 130-135F
Temp of flywheel is 125F
Outside temp 95F
Question/concerns
Are these temps normal?
Does the head temps and power head temps transfer and heat up the flywheel?
Sorry for all the question but I don't want ruin this old dear.
I will post pictures a little later.
Thanks,
David
