Amal twin jet
Posted: Thu Jun 20, 2013 2:32 pm
by spiderg
Hi guys, the fuel when turned on pours out the tickler hole, non stop. I can see lots of grit, is this probably the problem or should I be looking at something else?
Gerard
Re: Amal twin jet
Posted: Thu Jun 20, 2013 3:46 pm
by Michael
Well lots of grit is a problem, as the carb needs to be totally clean to work properly. The grit could be the cause of the flooding issue, or perhaps you have a float that doesn't, or a needle with a worn seat area therefore not sealing properly.
I would suggest you start with a through disassembly and cleaning of the carb as well as the tank, and fuel delivery lines.
Re: Amal twin jet
Posted: Thu Jun 20, 2013 4:58 pm
by Stelios_Rjk
That may be happening because,
1. The floater isn't moving freely in the float bowl.
2. The floater isn't placed to the correct point on the needle. There is a specific point to be attached.
3. The floater has a hole and some fuel inside.
