reverse gear on a kingfisher
Hi all-I hope to be taking my newly restored QB kingfisher for a test on the lake -Its just occurred to me that I'm unsure where Reverse gear is -are there three settings on the clutch lever (I only can find two)? Sounds a silly enquiry but I'd like to know before I go out on the water!Thanks --Weddigen
Re: reverse gear on a kingfisher
One click forward one click is reverse, you may need to adjust the linkage length.
Caution do not unscrew the rod from the gearbox.
