Petrol tank restoration and preservation
Posted: Sat May 25, 2013 9:43 pm
Had a few hours sunshine today, so was able to get the spray gun out, and give it the final coats.
Conserved the original decal, touched in the missing bits (took about 10 hours).
Sandblasted around decal, two etch primer coats, three coats of black cellulose.
Then acrylic clear satin varnish over decal.
Before
After
I think it was worth the effort, saved for future generations.
Re: Petrol tank restoration and preservation
Posted: Sat May 25, 2013 10:16 pm
You've touched that in by hand? I take my hat off to you. Top job!
Posted: Sat May 25, 2013 10:29 pm
Top job H-A very patient work! It would have been so much easier to remove the lot repaint and apply a reproduction decal. Preserving and remaking the old one instead is a really great piece of work.
Posted: Sun May 26, 2013 4:06 am
by david doyle
Beautiful work, thanks for sharing. Is the acrylic clear what makes it fuel resistant?
Posted: Sun May 26, 2013 11:33 am
The Acrylic may not be petrol proof, but I thought it was the safe option over the decal.
The Cellulose is petrol proof.
I will take care when filling, and not get petrol on the decal.
I am looking forward to getting it on the back of the boat.
Posted: Sun May 26, 2013 11:52 am
by phil
H-A what a great job! Did you do masking for the straight lines? What size brush do you use for fine work like that?
David you can get Dupicolor engine enamel in clear at NAPA and Can Tire in the spray can. It can be cured by heating as high as 300F, then it will be fuel resist when cured. You can also just let it age and cure that way. I don't think that they it in have black although I have used the one part black epoxy in the spray can from Can Tire on Seagull blocks and tanks and it does appear to be fuel resistant. The Ford engine enamel CDE 1605 is a very good match for the 50s OMC fuel pressure tanks.
Posted: Sun May 26, 2013 12:02 pm
by Stelios_Rjk
Astonishing restoration!! Hope to show us the whole picture later!
Posted: Sun May 26, 2013 12:14 pm
by PAULT50
Very impressive indeed..top job!!
Posted: Sun May 26, 2013 12:27 pm
phil wrote:H-A what a great job! Did you do masking for the straight lines? What size brush do you use for fine work like that?
Hi Phil, I use an edding 780 paint marker in gold. Draw each letter then tidy up the edges with a sharp scalpel.
Posted: Sun May 26, 2013 2:06 pm
by phil
Thanks H-A, I will look for one of those at the art supply store or maybe one of the office supply places.
Posted: Thu Dec 11, 2014 12:06 am
Had another go at a tank
Before
and after.
Hardest bit was removing previous restoration attempts, and sticky tape.
I will leave the main black finish that is not original as it looks OK.
Will do some more work on the big "S" as the shape is a little off.
Posted: Thu Dec 11, 2014 6:56 am
by Stelios_Rjk
Great job as usual!!
I also have to do the same on a little forty tank but due to luck of free time and experience, I postpone it all the time.. :|
Posted: Thu Dec 11, 2014 9:03 am
I am inspired!
Posted: Thu Dec 11, 2014 1:08 pm
Stelios, send me the little forty tank, I can do it for you..
