tcorrect tiller for a 102 TC 1963
Posted: Sun Feb 17, 2013 8:36 pm
by water bug
I am revitalizing a TC 102 Made in 1963. Please tell me if the correct original tiller is the same as earlier 102's that are kept on and friction adjusted with a big wing nut? Or is it correct to have a tiller same as used on most 40+ and century's?
Re: tcorrect tiller for a 102 TC 1963
Posted: Sun Feb 17, 2013 11:10 pm
It has the newer type tiller, the old 102's have a rounder mount.
My TC
http://www.wytewych.com/seagull102.html
Posted: Sun Feb 17, 2013 11:41 pm
Yes, the same tiller fitted to later century and forty models.
How about some more pics of your TC? We like pictures here
Posted: Mon Feb 18, 2013 11:54 am
by Jan
Good too see the TC arrived safely.
Pre 1957? 102's have the big tiller stub crankcase with rubber bushing tiller and wing nut.
After 1957? they changed the crankcase casting and using the later style tiller with stud and castle nut.
BTW the position of the clutch rod to the clutch lever is wrong. In neutral you can 'hook' the clutch rod end on the exhaust clamp.
Posted: Mon Feb 18, 2013 4:02 pm
by water bug
Thanks for the responses. I Just did not know , so checked with the experts. Here is a further picture. I still need to revitalize the carb, and clean and polish the points. WB
Posted: Mon Feb 18, 2013 4:04 pm
by water bug
Jan, Please tell me the correct way the shift should be put. Should the rod end point the other way? OR? WB
Posted: Mon Feb 18, 2013 4:49 pm
by skyetoyman
Rod end should point towards exhaust. the end should just hook over the exhaust clamp. It does tend to slip off
Posted: Mon Feb 18, 2013 5:39 pm
by Jan
Here some pics.
And you must turn the exhaust clamp 180 degrees.
Jan
Posted: Mon Feb 18, 2013 11:00 pm
by water bug
Jan, Thank you. Aside from the things you mention, and the tank, which is out for painting, the TC 102 assembly is complete. See Pictures. WB
Posted: Sun Dec 15, 2013 11:41 am
by Stelios_Rjk
Hello guys,
A TCL saw some of his family on that balcony, came down and settle at my home!
I am writing to this post as there are some similarities to the one Waterbug has. The serial is TCL 835W7, after Charles letting me know that "W" is wrong and it should be an "M" upside down that makes it manufactured on November 1967. This model was supposed to be produced until 1966 so some messing up has occurred. 1967 is the year that the MK2 started to be used. Mine has an MK2 with the big flywheel holes and the plastic case on the points. The tiller, the thrust block and the cylinder is the same as Waterbug's. But the water pump housing looks like a much later one. The tank is a long range one and the exhaust made of alloy.
How does all these sound? Original or bitsa?
All parts has the same dirt on so in case changes have occurred it should have happened many years ago.
Posted: Sun Dec 15, 2013 3:52 pm
Not the only one stamped with a "W".
Only what I read.
speculates that the 'W' was added in place of the month letter when an outboard was fitted with a Wipac (Mk 2) ignition assembly.
Posted: Sun Dec 15, 2013 7:00 pm
by Stelios_Rjk
Thanks! Any clue about the water pump housing?
