FVP Drive Shaft Cover & Engine Gaskets
Posted: Wed Aug 01, 2012 12:05 pm
Hi,
Could somebody tell me if the drive shaft cover on my newly aquired FVP
is threaded into the water pump housing,I think I can see the start of a thread
but do not want to damage it in any way.
Also do I have to anneal the metal gaskets either end of the cyl block or would a
clean up and a thin smear of RTV be enough on rebuild
Is there any other thing I should be wary about when rebuilding the FVP,
Thank you in anticipation
CC4
CC4
