Crank cracking
Posted: Wed Jul 11, 2012 7:19 pm
I'm decided to strip and clean up the 1969 ish wipac 102 I'm taking to the Hayling bash as back up to H-A's engine. Upon stripping found it to be in good order apart from the crank. Their is a crack running around the web from one weld to the weld at the other end. The 2 sides will move together and thus close the crack
Has anybody seen this before? I'm loathe to reuse it without perhaps a blob of weld across the crack and redressing.
The good news is that I have a crank from a 1974 WSPCL that has a terminally cracked block, so is a good source of spares. The crank from the century looks identical both in looks and dimension.
Can anybody advise if the cranks are the same? Also are the con rods the same? I'm not that well up on centuries as 102s are my engine of choice
Proper seagulls!
thanks.
thanks.
