Champion D16 specs
Posted: Fri Apr 27, 2012 6:37 pm
by Donald A
Can someone enlighten me about what sort of thread size this is? All I wanted was a thread chaser that would clean the whole female thread!!
It seems to be 22 mm across flats, but with an 11/16 of an inch diameter shank (0.6875) - but my thread gauge will not fit - it seems to be between 18G and 16G, but my zeus book does not match up - the closest would seem to be an 11/16-17 UNF, not in the book
The nice thing about Whitworth is that the non expert has a good chance of understanding it - but with this one I'm lost!
Donald A
Re: Champion D16 specs
Posted: Fri Apr 27, 2012 7:00 pm
Donald A. 18mm thread size.
Posted: Fri Apr 27, 2012 8:05 pm
Spark Plug Thread Repair Chasers 18mm, search on ebay for this.
Posted: Fri Apr 27, 2012 11:55 pm
by Taspiper
1.5mm pitch, just had to recoil one of mine
Posted: Sat Apr 28, 2012 10:00 am
by Donald A
Thank you all for the replies - I'll pursue it accordingly
So what thread in my zeus book does this take me into?
Posted: Sat Apr 28, 2012 12:51 pm
by Taspiper
I'm not sure if it's listed in Zeus as the book only covers common sizes. Spark plug is M18x1.5 which falls in to metric fine. There is also 18x1, 18x2 and metric coarse is 18x2.5. On top of this there are special pitches and left hand too.
If your wanting to know if it's in the book for tapping drill size it's just 18mm-1.5 = 16.5mm near enough.
Posted: Mon Apr 30, 2012 9:34 am
by Donald A
Thank you for that - two more bits of the jigsaw. I did not begin to think that a spark plug "made in the usa" for an engine designed round whitworth would have anything metric on it - and did not realise that zeus does not cover everything....
I am now on the hunt for an 18 mm chaser, and a workshop book that lists all the threads, not just some of them!
Posted: Mon Apr 30, 2012 10:18 am
by Taspiper
Why a thread chaser, just get a tap. If the thread is stuffed don't loose heart as you can repair it by helicoil or better still timeserts.
I doubt you will find one book that will list all threads, there's just too many and then there's specials by manufacturers that want you to buy their parts. You just have to measure them.
A trick for threads you can't get or see you thread gauge in is to screw a bit of soft scrap wood into the thread then use your pitch gauge on that.
Posted: Sat May 05, 2012 8:33 am
For those of you interested in D16 and similar and have 102 engines, Champion D15Y.
These can not be used on 40 series unless you know what you are doing.......pay attention to that and you will be fine.
Some square blocks, not all so investigate and do paying attention as well.
Trolling revs to flat chat, give them a try and let us know?
Posted: Sat May 05, 2012 9:44 am
The reason a chaser is preferable to a tap, firstly cost but secondly & perhaps more importantly is that many Seagulls were fitted in the factory with Helicoil inserts, you will run a greater risk when using a tap that it the tap will bite on the helicoil & damage it or tear it out, giving you a more complicated & costly repair when all you wanted to do was clean the thread up!
Posted: Sat May 05, 2012 1:38 pm
by Donald A
Thank you - I had already found out that the chaser is about 1/3rd the cost of a tap, so it's on order!
Why did the manufacturer need helicoils - doesn't quite sound right?!
Posted: Sat May 05, 2012 11:02 pm
by Taspiper
Donald A wrote:Thank you - I had already found out that the chaser is about 1/3rd the cost of a tap, so it's on order!
The idea is that the coil is usually stainless steel and there fore gives you a stronger thread by both material and larger surface area of the larger thread of the coil. This is common practice for quite a bit of machinery and in plastics. I feel I would rather a thread in aluminium and when that is buggered then recoil it for if the coil is stuffed it makes for a harder repair. I prefer timeserts which are a solid insert.
Good point on the chaser Charles I didn't really pick up on that as we don't use them because of the large amount of taps lying around, good and buggered
Posted: Sun Aug 26, 2012 6:28 pm
by Donald A
Charles was right - there is a helix insert into the original thread, which I only recognised after looking at a u tube video of how to insert them - it has a sharp point at the lead in, unlike ordinary threads with a smooth lead in - and the whole thread has 2 diameters - the one deeper in is wider. The chaser worked well, although it's a pity I don't have a parts cleaner to finish of the job
Thanks to all for a good result
Donald A
