amal carbs!!??
Posted: Sat Nov 12, 2011 12:27 am
by nwcove
im trying to revive a wscl 721dd8 with an amal carb, i want to mix and match parts from a sl 2081d9 with the amal carb. both barbs appear to be identical, are they? ( the threads are stripped where the float bowl attaches to the bottom of the carb on the wscl, and i want to use just enough parts from the sl to solve the problem)
thanks
tim
Re: amal carbs!!??
Posted: Sat Nov 12, 2011 1:06 am
They are both Century motors, same CC and hp, Would say they are the same.
Re: amal carbs!!??
Posted: Sat Nov 12, 2011 4:06 am
by nwcove
thanks keith, im going to try it now, the carbs do measure up as identicle, just didnt want to find out the hard way that i was wrong.
tim
Re: amal carbs!!??
Posted: Sat Nov 12, 2011 9:48 am
Have a look at the jets. The 1978 motor may well be jetted for a different fuel mixture.
There are little numbers stamped on the jets. If they're the same then no problem; if they're different then the later one will be 25:1, the earlier one 10:1
Re: amal carbs!!??
Posted: Sun Nov 13, 2011 1:26 am
by nwcove
thanks guys.
i hate to ask stupid questions, but where do i find the jets in the amal carbs? my other bs motor has a needle and has been converted to 25:1. ( im new to gulls, and dont want to ruin the ones i have!)
Re: amal carbs!!??
Posted: Sun Nov 13, 2011 1:33 am
Re: amal carbs!!??
Posted: Mon Nov 14, 2011 12:06 am
by nwcove
thanks keith, that is exactly what in needed! (now when i ask more questions...i will be able to use the right terminology)
.....is there an easy way to remove the jets without having the tool?
thanks
tim
Re: amal carbs!!??
Posted: Mon Nov 14, 2011 1:12 am
Don't know if it will work for you, depends on what you have, but it use a radiator key.
