Stuff
Posted: Mon Oct 31, 2011 10:25 am
Well - not for sale really - free parts:
A Forty Plus powerhead - FP224E9 -crankcase, cylinder, crank and piston, head and Wipac magneto flywheel and backplate, with drive tube and chromed exhaust tube. Stiff to turn over, but uniform throughout a rotation, so I would believe the crank is not bent.
A powerhead pretty much as above - FP 2087C0 - spins over freely - drivetube is rusty but not pitted - aluminium exhaust tube in good condition.
A crankcase and crank, with Villiers magneto backplate - SJP20009L
Two steel petrol tanks - little or no rust internally, no dents, but one pushed in slightly on base - both have mounting brackets.
Two - 4:1 gearboxes with 5 blade Hydrofans in good condition, and with disengagement yokes. Gears in one of them good - other one unknown.
One Forty Plus gearbox and waterpump housing - gears reasonable/useable.
Don't want to post these parts particularly, but if distance is a problem, will post at cost, though the tanks might be a worry. Otherwise, collect from Huntingdon or meet up at a reasonable distance..
Rick.
Rick.
