Balancing a Seagull Engine
Posted: Mon May 09, 2011 10:37 am
by The Tinker
Anyone out there tried to balance the crankshaft and flywheel of a seagull. It is done in motor cycles to remove the vibration.
Re: Balancing a Seagull Engine
Posted: Tue May 10, 2011 12:12 am
by Rex NZ
Interesting
I've thought about the same.
Was thinking of modifying a flywheel with a series of steel plugs to adjust the balance
The problem I envisage is achieving a meaningful measuring system
Rex
Posted: Tue May 10, 2011 10:17 am
by The Tinker
With single cylinder engines you can not get perfect balance. You just move the vibration to a different rev range. The research I have done suggests that 65% balance is about the best that can be achieved. This is the difference between the power stroke and compression stroke. I am tiring to find out how to do the calculation. Static balancing seems to be the best way to go.
Posted: Tue May 10, 2011 2:36 pm
Andy I've played with the balance in some of my higher revving motors, they're never going to run smooth, with luck you can move it to a point where the boat doesn't resonate enough to loosen your fillings.
I always do the flywheel so that it's completely neutral, as the thought of one of those shaking itself to bits at 5000+ revs right by my ear makes me watertight below the belt.
Posted: Tue May 10, 2011 8:13 pm
by The Tinker
So what you are saying Charles is that the flywheel is balanced on its own. The flywheels seem to be very out of balance so might be a good place to start.
Posted: Mon May 23, 2011 6:27 pm
Andy here's some pictures of the bar I use for flywheels, it fits all of them from the Marston to the Seagull Sport.
Sorry I take such a dreadfull pic all it is is a high tensile threaded bar with turned down ends with 2 threaded cones to centralise & hold the flywheel.
Posted: Mon Oct 15, 2012 6:10 am
by Chilli Dog
then there is the prop , both static and dynamic balance need to be attended too .
