Comments on: Before you start your Seagull for the...
Posted: Sat Apr 30, 2011 6:46 am
by BrendanM
Please use this thread to comment on the Before you start your Seagull for the first time... page.
Re: Comments on: Before you start your Seagull for the...
Posted: Mon May 02, 2011 4:52 pm
by BrendanM
Hi All,
We still need someone to identify these parts on Keith.P's diagram please.
Sparkplug.
Magneto (flywheel).
Throttle Cable.
Throttle Lever.
Tiller Handle.
Carburettor.
Propellor.
Dog Clutch.
Gearbox.
Gearbox Drain Plug.
Fuel Line.
Filters (2 of).
Cheers,
Posted: Sun May 08, 2011 10:23 am
by The Tinker
Couple of hints when getting a garage sale outboard. Before starting I remove the spark plug Carb and top of the flywheel. First I get my oil can with a little SAE30 in it I squirt A little oil down into the crankcase and turn the engine upside down turn the engine over by hand slowly to get a little oil into the top bearing, then I turn the engine right way up to clean and check the points. Have a good look at the low tension wire. I then put the top on the flywheel, I hook the spark plug on to the lead and use the starter cable to wind the engine over to see if it has spark. The excess oil you put in the top bearing will have drained into the bottom bearing and lubed that. It is also useful to squirt a little oil into the spark plug hole before you check for spark. I clean out the carburetor next. Usually it is completely dismantled and cleaned, then reassembled. When you have the engine upside down if there is any old fuel in the tank this is the time to drain it out. Fill tank with fresh fuel and refit spark plug. Prime carb and it should start after a couple of pulls, hopefully. To run engine for a while in a drum of water it is essential that the propeller is removed, so the engine can pump water properly.
Posted: Sun May 08, 2011 12:55 pm
by Daryl
I picked up a very good looking 102 seagull at a garage sale afew years ago & was very lucky that i pulled the motor apart before starting it. What i found was the bigend bearing cap screws were not tied of & only finger tight, a disaster waiting to happen very wary now.
Posted: Mon May 09, 2011 3:50 am
by BrendanM
The Tinker wrote: To run engine for a while in a drum of water it is essential that the propeller is removed, so the engine can pump water properly
Daryl wrote:I picked up a very good looking 102 seagull at a garage sale afew years ago & was very lucky that i pulled the motor apart before starting it. What i found was the bigend bearing cap screws were not tied of & only finger tight, a disaster waiting to happen very wary now.
Nice posts The Tinker and Daryl, any chance of diagrams or further simple posts telling us how to take the prop off and where are the bigend bearing cap screws are please? ...Then I will add them to The Guide.
Cheers,
Posted: Mon May 09, 2011 5:56 am
by Daryl
Hi Brendan, The Nos & lines are hard to see in green would be better in black. As best i can read the Nos start at the top as1 & goes down RH side as 2,3,4 Etc. 1,Flywheel nut. 2,Cylinder Assy. 3, Fuel cap breather screw. 4,Fuel cap. 5, Fuel tank. 6,Spark plug cover. 7,Spark plug. 8,Ign lead. 9,Cylinder head. 10,Exhaust tube clamp. 11,Cooling water pipe. 12, Exhaust tube. 13, . 14, Drive spring. 15,Washer. 16,Split pin. 17,Propellor. 18, Gear case screw. 19,Oil filler plug. 20,Gearcase. 21,Water pump impellor. 22,Gearbox screw. 23,Drive shaft housing. 24, Thrust block. 25,Drive shaft. 26,Clamp screw. 27,Tilt catch. 28,Tiller handle 29,Magneto base lock screw. 30, Magneto base plate.31,Throttle. 32,Flywheel. 33, Flywheel cover. Hope that helps the carburettor isnt in the diagram, perhaps some one can post an exploded view of the carby here, as my pictures are to big for this site. Daryl
Posted: Mon May 09, 2011 6:11 am
by BrendanM
Daryl... you diamond!
Anyone got a problem with the descriptions? If not, it's going up.
I doubt it ...
Can I help you with the pictures?
Cheers,
Posted: Mon May 09, 2011 6:38 am
by Daryl
Have started in the guide. Pics are Ok if i use a camera with poor resolution.
Posted: Mon May 09, 2011 3:41 pm
If its any use on some part of the site please use it.
Posted: Tue May 10, 2011 12:12 am
by BrendanM
Thanks Keith, that's great, I am sure we can use that. :D
Posted: Fri Jul 08, 2011 10:30 pm
by John@sos
Keith that is extreemly cool!
SOS
Posted: Sun Aug 07, 2011 8:36 am
by umitsayman
Keith has done a perfect, cool job.
Yet, I liked his avatar most!...
Wish we can see a bigger gif somewhere.
If it exists, what's the link?
Have fun!... Best of everything from Turkey...
