Bolt on recoil starter
Posted: Wed Mar 30, 2011 11:08 am
by Buzzook
Found this on Fleabay. Is it the legit one that Seagull made or can anyone tell me what it is?
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
Re: Bolt on recoil starter
Posted: Wed Mar 30, 2011 11:27 am
by Buzzook
.....knew I'd seen this somewhere before....at least it looks the same?????
http://www.saving-old-seagulls.co.uk/no ... /siba1.jpg
Anyone of you anoraks out there suggest what Seagull models this might or might not fit?
Seller has confirmed the recoil works and it definitely came off a Seagull, so is almost certainly a Siba.
Are they any good or not?
Posted: Sat Apr 02, 2011 9:33 am
by SAE140
Buzzook wrote:.....knew I'd seen this somewhere before....at least it looks the same?????
Fits the standard Seagull crankcase, by courtesy of some extra long bolts which replace those which hold the crankcase halves together.
Any good ? Well, the Siba recoil and actuating mechanism is exactly the same as that fitted to the 90/110.
The big difference is that when using a 'cage' it's necessary to fit spacer washers between the cage and the mechanism housing in order that the top of the adapter boss just clears the bottom of the recoil mechanism housing - bit of a hassle, but only needs to be done once.
One drawback for earlier engines is that it makes 'pulling the top off' to check the points setting a bit more of a production, and might tempt the owner to ignore basic maintenance ...
Posted: Fri Jul 15, 2011 3:10 pm
by Daryl
He actualy got 17GBP for that! I bined the one removed from the motor ive got.
