carburetter
Posted: Mon Feb 28, 2011 10:20 pm
by andyboy
how do u get the cover off are 1968 featherweight can u help
Re: carburetter
Posted: Tue Mar 01, 2011 12:01 pm
by Vic
Cover ? What do you mean by cover?
Diag of villers carb on the main website
http://www.saving-old-seagulls.co.uk/fa ... s_carb.htm
unscrew the ring #4
I guess a 1968 one has a metal bowl Thats held by a nut underneath. Plastic ones just unscrew
Re: carburetter
Posted: Tue Mar 01, 2011 3:44 pm
by andyboy
yes no 29 on the diag so it just a nut under neath mate thank you
Re: carburetter
Posted: Tue Mar 01, 2011 6:19 pm
by Vic
It's a bit more than "just a nut" but it unscrews then the float chamber will fall off.
There is a fibre washer between the two so watch out for that.
If you remove the centrepiece/jet # 11 watch out for the needle #30 and the washer #12
