Are there two types of block and head for small seagulls (40 series)? The reason I ask is that I've come across a small seagull block that seems to have the correct bore length and diameter (piston fits), exhaust and water ways in the same place but the carb mounting flange/induction bracket on the block body is not in the centre of the block as it is on my other 3 40+ gulls, its towards the edge/side. It looks if anything 'younger'. Did Seagull alter the 40+ block over time?
Also, did some gulls have screws rather than bolts securing the head? I'm trying to work out if these are original features or something that has been buggered about with? (that is more buggered about with than is desirable)
confused
Ken
