Thanks to having a degree i'm pitifully short of money and would like to sell/swap these bits in the hope of getting closer to making a couple of seagulls work.
I've never used photobucket before, wish me luck!
Did that work? I guess i won't know until i hit submit...
Anyway here we have a Villiers flywheel/magneto assembly. This came off an SJP 40+ and i think the coil is dead. I have now got a Wipac jobby so this is up for grabs. I don't really want much for it, i'd be happy to accept a bit less than the ebay prices but would prefer to swap...
things what i want:
-standard shaft 40 series square section drive shaft with impellor
-thrust washer for front end of gearbox
-1.25 inch BSF bolts (allen key type preferably or normal slotted if thats all you have) for forty plus gearbox
-tilt hook+pin for forty series bracket
-throttle lever to suit amal carb
So if you have any of the above in a combination whose swap value you deem similar to my offering above, or you wish to make me an offer of actual money, let me know!
Cheers,
Rich, Plimuff
