Introduction and is it treatable?
Posted: Fri Nov 26, 2010 9:08 pm
I'm fortunate to have stumbled on this site and its obvious sense of humour after doing an idle search on British Seagulls.
I remember Seagulls as a bit of an oddity around the Durban Yacht Club basin in South Africa, raucous, smoky, noisy, and usually transporting drunken yachties in small tenders on a weekend night.I now live in Ireland, a place of great beauty and plentiful lakes where the trout live well beyond the reach of my fly-casting arm.
so I have been looking out for a boat small enough for my areseritus to drag/handle into the water and a outboard motor light enough not to give me a hernia.
My Hobby is fixing things (restoring I tell my wife), sometimes so that they are actually worse than when I started, (my 1942 Harley Davidson WLA and a failed restoration of of a 1940's Packard Roadster spring to mind) but fortunately, my successes outweigh the failures.
I'm currently busy with a 1963 Triumph Spitfire, have finished off a 16 Fireball Sailing Dinghy and had a 15 foot Dinghy donated.
so looking on fleabay uk under outboard motors I came across a plethora of seagulls and my eyes lit up.
I looove classic machinery.
also being wary having made a few tostesterone and wine charged impulse purchases on Eabay previously I googled Seagull Spares and found this here superb website and forum.
As the forum does not have a search function I will probably ask a lot of questions previously answered and beg your forbearance.
from my memory, Seagulls did not have a reverse gear and neither could they idle, it was either go or wrap the starter cord and restart?
I see that some of the later models (forties) had a clutch? would this allow the engine to idle rather than trying to calculate how much fuel is left in the carb bowl?
Standard shafts seem to be plentiful whereas longshafts seem to be rarer?
if so, how much play/choice do you have on a longshaft (which i would prefer) to still only get the required immersion on a small transom dinghy?
Or can I convert a standard shaft to a longshaft when I find the 24foot sleeps three under sail on the lake I dream off?
really appreciate your advice.
Thanks
Dick
Thanks
Dick
