rainy day project
Jerry In Maine
rainy day project
Post by Jerry In Maine »
we had a storm come up the east coast, and since i live on the coast i had to find something to door indoors.
i thought i try to improve on a flywheel cover that'll go on the engine i'm currently working on. the idea wasn't to make it look new but rather to clean it up and improve the lettering. here's how i went about it:
* first give the cover a good cleaning and allow to dry. make sure to get any grease or oil off.
*next mask off the areas near the lettering. you don't have to be exact.
*spray paint black in thin mist coats and let dry well in between. use just as many coats needed to get an opaque coating. the lettering is lightly stamped, don't try to fill up the recesses.
* allow to dry thoroughly - a light bulb placed nearby will speed drying.
*take a bit of fine grit wet/dry sandpaper. all i had was 400, but i think 600 grit would be better. wet the surface with water and rub the sandpaper LIGHTLY over the letters. go easy - soon enough you'll start to wear off the paint outside the recessed areas. don't apply pressure to the point where the paper dips into the recesses.
note: if you get a letter just about perfect STOP! use a toothpick or similar to remove the rest. don't use the sandpaper any more than necessary.
*when you get things looking as best you can fill in difficult areas with a fine point black marker.
* finish up with a coat of clear enamel.
the final product shown here still needs a bit of work (my fine point marker gave out with still some to do) but i think its an improvement and doesn't look too bad despite the "character" it shows from years of use.
start
start
mask / paint
mask / paint
pulley needs work too
...looking better
...looking better
Re: rainy day project
It looks like "Outboard" is misspelled.
Can't do that on my one as I only have the British Seagull logo, but found it easier to paint with black enamel. Once this has dried, chuck it in the lathe, give it a spin, then rub excess away with some scotch brite. Job done!
Jerry In Maine
still needs a bit of touchup. theres a small scratch across that 'a' making it look like a ''u'. the cover was scratched and gouged quite a bit - but looks better and will do the job!
phil
Post by phil »
Good job that is a big improvement.
Jerry In Maine
thanks phil! wanna buy it back?? :wink:
went a bought a fine tip marker to touch up what the paint didn't fill in. afterwards another coat of clear enamel and she looks just fine.
phil
Post by phil »
Same price? Value added. Sure :D
