flywheel key
Posted: Sun Sep 26, 2010 11:21 pm
by billyboy
i have a few flywheel keys and none of them seems to want to stay in the hole in the crankshaft. l have previously removed and replaced others with no problem and so i was wondering if there was a trick i was missing somehow that i had not needed before.do crankshafts have their own key that is matched to fit them( like the thrust washers on the prop shaft) or should any key be able to fit? woud appreciate any advice.
Re: flywheel key
Posted: Mon Sep 27, 2010 12:27 am
A blob of grease helps.
Re: flywheel key
Posted: Mon Sep 27, 2010 12:39 am
by billyboy
thanks hugz. will try that later today. frustrating though as i have a rebuilt century ready to go but for that tiny piece of metal!
Re: flywheel key
Posted: Mon Sep 27, 2010 9:54 am
by billyboy
problem sorted. l just had to slightly grind one of the keys into a better shape to make it a tight fit.
