here's a tip from a seagull newbie that might help other newbies...
while trying to free the top of the lower unit from the chromed shaft tube;
i removed the pinch bolt and expected the tube to slide out of its mounting hole - but it didn't. it was stuck
. tapped with a leather mallet, no good, still stuck
. tapped some more but a bit harder...little voice in head tells me that something is going to break if i "tap" any harder
. cursed some and that didn't help either
. sprayed with penetrant...nothing
. it was like they were welded together.
then i came to my senses and made a small wooden wedge then inserted it between the gap that the pinch bolt squeezes together
. gave it two or three light taps which pushed down the wedge which spread the sides, and the shaft tube fell out of its own accord.
