Forty/Featherweight up and running
Posted: Wed Apr 07, 2010 6:56 pm
Hi all, hope this ok to open up another thread!
At long long last the little bugger is running
It was a nightmare after days of doing literally everything but what a learning curve it was!
Made up a piece in work to go into my drill, took off the carb, prop, and took the plug out, and span the flywheel for five minutes.
Did not increase the size of the spark!
Put the carb back on and the plug in, pulled the cord about ten times, still no joy!
Then thought bugger it, I decided to put the drill back on to the flywheel, pulled the trigger and after about ten seconds she flashed up and I kept the drill on it to keep her going!
I left her running for about five minuets, then stopped it to cool down.
After cooling down she fired up on the third pull with a great water flow.
I would once again like to thank everyone for their help and advice in helping me to get this stubborn old girl going!
I now know if I ever come across one like this again i will put the drill to it. A great learning curve for me!
