century compression.
Posted: Wed Jan 13, 2010 2:52 am
by RAY SWANN
Hello all.
What is the normal compression reading for a Seagull century that has done a fair amount of work.
Mine is 65-70psi and I think this may be a bit low for a 100cc engine.
Any one any ideas ?
Thanks.
Regards all.
Ray.
p.s. The transom to motor bar (pivot bar) on my engine is brass.is this correct?
ROLL ON SPRING. :|
Re: century compression.
Posted: Wed Jan 13, 2010 3:01 am
http://www.saving-old-seagulls.co.uk/fo ... f=5&t=1678
Sorry not in a chatty mood.......... so bluudy hot! Something has gone terribly wrong with the weather :(
Posted: Wed Jan 13, 2010 3:03 pm
by billyboy
you should be happy. a new 102 motor was supposed to have about 60 psi but would still start on half that.so 65-70 is great!
Posted: Wed Jan 13, 2010 3:16 pm
by RAY SWANN
Thank you billyboy.
Thats good news.
Just thought the compression would be higher than on my 40s.Thanks for the information.
ray
Posted: Wed Jan 13, 2010 3:22 pm
by billyboy
the 64's were supposed to be about 135 psi new.they would also start with about half that at a pinch.
Posted: Sun Jan 24, 2010 2:56 am
by rosbullterier
Yes the pivot bar is brass.
Check your compression tester. 50psi is very good.
The 40 compression should be greater. See:
http://www.britishseagullparts.com/engi ... ession.htm
Posted: Sun Jan 24, 2010 2:59 am
by rosbullterier
Further to that.
What is the engine number? I'm very interested in whether that cylinder head makes a difference.
