gearbox oil question
Posted: Wed Jan 06, 2010 3:29 am
by SeagullGuyUSA
Can I use SAE 140 Hypoid gear oil in the gearbox of a 40+?
I will most likely be using this : http://napaonline.com/Search/Detail.asp ... 006410049#
Re: gearbox oil question
Posted: Wed Jan 06, 2010 11:22 am
by 40TPI
Most likely..........if it is a single weight oil; even if it has additives. ( I gave up checking when the link asked for a zip code....)
Much quicker to answer this question from the FAQ info here.....
Have a look at the FAQ page on the main site here:
http://www.saving-old-seagulls.co.uk/faq/faq.htm
This has all the info and more on these types of questions.
Peter
Posted: Wed Jan 06, 2010 4:37 pm
by Vic
Hypoid oils contain EP additives to prevent the wear that would otherwise occur with hypoid gears due to sliding between the load bearing faces.
As it says in the FAQs EP additives can cause corrosion of bronze components at elevated temperatures. Seagull gearboxes do not run at elevated temperatures!
Posted: Wed Jan 06, 2010 9:25 pm
by SeagullGuyUSA
Thanks for the info!
