Hi,
We have had a few enquiries and suggestions from some of you regarding the new forum format, so I thought perhaps the experts among you could help out the newbies?
One thing I would like to draw your attention to is that you can change the size of the text on the forum by using the "A" button to the top right of the screen. Also, if you click on the "User Conrtrol Panel" you can choose a different style from the default one, which may make things easier to read, or just give you a change.
I have also now enabled you to upload your own avatar (a picture that sits alongside your username in any posts you make).
If you have any specific problems, I am sure that there are those out there who will be more than willing to help, they're a friendly bunch, so I would encourage you to post details of your difficulties here and we will do our best to help.
One thing I would like to know is; how do you go about quoting someone elses post in yours? I know some of you have worked this out already!
Cheers,
Brendan. SOS
Re: Forum tips and tricks
Posted: Wed Aug 05, 2009 7:10 pm
by Vic
Hi-light and copy the words to be quoted.
Hit the quote button and paste them between the tags
Or by using the Quote button in the bottom RH corner you can reply quoting the whole post but thats a real PITA
Can change the colour and size as well if you want
Posted: Thu Aug 06, 2009 7:09 am
by Waggles
Just a little teensy weensy bijou problemette I have found that the smilies dont work. Note: that I am at work and forced to use antiquated IE6 so its probably that. I guess I could put the tags in the text directly ( if I knew them ) but pressing the actual smily buttons has no affect.
Posted: Thu Aug 06, 2009 10:42 am
Very Happy With It All!
C.I.
Posted: Thu Aug 06, 2009 2:45 pm
by Vic
Smilies dont work?
Smilies do work
Perhaps you have disabled them but if you cannot see them above you have opted not to display them
Posted: Fri Aug 07, 2009 7:19 am
by Waggles
I am sure Smilies work on other machines but not on mine. I have them enabled and can see yours, right now I can see them smiling at me to the right but pressing them has no affect look:
See?
It actually reports 'Error on page' in the IE message bar at the bottom left so I don't doubt it is the old version of IE I am using here. Just flagging it up in case anyone else has problems.
Posted: Fri Aug 07, 2009 7:20 am
by Waggles
Oh and I got THAT smily by entering the code! should have said!
Posted: Fri Aug 07, 2009 1:20 pm
by BrendanM
Waggles wrote:I am sure Smilies work on other machines but not on mine. I have them enabled and can see yours, right now I can see them smiling at me to the right but pressing them has no affect look:
See?
Hi Waggles,
I disabled JavaScript on my machine, by setting the security level to High from Tools/Internet Options in IE(8) and was no longer able to insert Smilies (or use the buttons at the top of the edit box)... This is in IE(8) but will be there in the options of earlier versions of IE.
The buttons and the smilies all use JavaScript to insert text (in code) into the edit box. There are two things you can do... either lower your security level to Normal, or add http://www.saving-old-seagulls.co.uk to your trusted sites and make sure that the trusted sites security level is normal, or at least allows JavaScript to run. Then re-load the page and things should work better for you... Hope that helps... let us know either way, like you say, you're probably not the only one.
You can do this by right-clicking and selecting 'Paste', this will give you a lot of stuff you don't need, along with the dimensions of the video... you should edit out everything apart from the "http://" to the "&fs=1"... When you select 'Paste' it will look something like:
We hope that there will soon be a button called 'YouTube' in the Forum which will take all the messing around away... I'll let you know as soon as it's ready, but for now, this is the best we can do.
Posted: Thu Aug 27, 2009 1:35 am
I did it!!!
Hugo
Posted: Fri Sep 25, 2009 9:38 pm
by BrendanM
Hi Guys,
I have now added a YouTube button to the Post A Reply form.
As you can probably guess, it lets you embed a YouTube video in your post... easily!
All you need to do is copy the URL code from the YouTube site, press the YouTube button in the Post A Reply form and paste between the [YouTube] and the [/YouTube].
Any idea what Yahoo [Bot] is that comes up as a registered user from time to time? It is not on the members file. Looks positively sinister!
Cheers Hugo.
Posted: Thu Oct 01, 2009 3:13 am
by BrendanM
Hugz wrote:Any idea what Yahoo [Bot] is that comes up as a registered user from time to time? It is not on the members file. Looks positively sinister!
Cheers Hugo.
Hi Hugo,
The Yahoo [Bot] you mention is an automated program that indexes our site... nothing to worry about, it's actually good for us. There are quite a few (ro)Bots that regularly wade through the forum for search engines like Yahoo and Google.
