Hi,
Have just been given a forty plus mark 2 which starts and runs great but drips oil, apparently from bottom of exhaust tube, after running. How worried should I be?
Cheers,
Mouse
Oil leak
Its not abnormal for 2 stroke outboards as a whole but Seagulls are particularly bad because they run on such an oily mix.
You can also get some oil leaking from the gearbox as well when you lay it down. Be sure to protect the boot of the car with some old newspapers when you transport it.
And the residual fuel in the carb bowl will also spill out in the car boot.
