Setting clearance on contacts
Posted: Wed Feb 18, 2009 11:47 pm
Help! I recently bought a small day/fishing boat, with it came an old seagull. I was told it was a good runner but had been sitting for a while. When i eventually got round to having a look at it it did not want to start!
I then, perhaps a bit foolishly, decided to strip and rebuild it myself. Upon stripping the engine i was surprised that the piston and cylinder were in very good condition. The only major thing was the waterways. All in all i spent a good hour with the aid of a 5mm drill bit and a screwdriver to clear the lower waterway.
Anyway i then built it back up again replacing the gaskets, gearbox oil, spark plug and throttle cable and hae now found that i hardly ever get a spark, maybe once every 20 pulls - not so good! I tried the method of spinning the flywheel with a drill and socket but had no success. Eventually iv managed to get the flywheels off and have found the clearence at the contacts to be between 0.6 and 1mm. Too big? The thing i cant work out how to do in change the clearance. Am i totally missing something?
Hope someone can help
Cheers, Gav
Oh and its a 1973 or there abouts 40 something.
Cheers, Gav
