1952 FV erratic running
Posted: Sun Aug 31, 2008 8:00 pm
Acquired an FV ....stripped as much as needed to get it running
fuel system & tank fully stripped and cleaned
overhauled the magneto and set points ...set it up with a known good HT lead
starts well in test tank, on 10:1, sounds great, pumps very well....then slows, burbles and gurgles and finally stops
in this later stage anything off full throttle it dies
noticed at this 'dying stage' it's blowing air out of the carb inlet instead of sucking in ...fuel collecting in the air intake bell mouth
Also seems to be blowing a bit of water out of the drive tube holes
let it get cold and it's the same all over again ...starts straight away but after 10 mins misbehaves again
any hints ????
any hints ????
