40 minus Restoration
Re: 40 minus Restoration
Post by Stelios_Rjk »
The next will be shiny zinc plated, just making some experiments to find the correct mAmps :P
Chilli Dog
Post by Chilli Dog »
Oyster , great job on the photo and research . excellent .
minor error on the label of the photo I believe . you have labelled it 1/8 bsp . I think you would mean 1/4 bsp for the carb nut side .
Chilli Dog Racing
Well spotted. Photo changed.. :oops:
Chilli Dog
Lol I only mentioned it to prove some one reads your posts :lol: :lol: if some one used it to make an order or pass on incorrect information as gospel .
I only need one copper fuel line and one water line in copper so I'm going to make mine out of scrapped lines but I'm sure your information is invaluable to others . good job :D
Chilli Dog Racing
If this helps
Wow that's impressive! I was wondering what the dimensions of the banjo were!
Banjo as well.
Niander101
Post by Niander101 »
Howabout a crank? 8)
Its not that easy to do you know.
Any use?
Early fifties. LS or 102. Only the cutout for the key was differently placed.
Niander101
Yes not bad.
What is the diameter of the crankshaft where the bearings fit? Could it be 5/8"?
Niander101
.6250=5/8
Now look at the size on the drawing and compare
The ID of the bearing is 5/8, the crankshaft is ground slightly smaller to provide oil clearance.
Please note that this crankshaft has a minimum clearance of 1 thou & a maximum of 1.25 thou.
This particular crank is one of the low balance versions that was only used for quite a short period.
I see. I am asking because I have found some 5/8" reamers :mrgreen:
