Page 4 of 4
Re: fixing two Century (or at least one)
Posted: Fri May 06, 2022 12:03 pm
by Romainpek
Thanks for the tips Charles !
Posted: Mon Jun 20, 2022 12:57 pm
by Romainpek
I received some spare parts from John and now I started the reassembly. I'm sure I will realize the need for other parts as I progress.
My exhaust tube's chrome was too damaged to keep, so I sanded and polished it. Now it's plain copper, I hope it will keep its shine a bit. It's still battered because my skills are low for bodywork.
Also the drive shaft had to be painted, for the same reason, the chrome was too damaged plus the steel underneath rusty. I also repainted the block, at least this was originally the case.
Here is where I stand today, with a very colourful Seagull
Posted: Tue Jul 05, 2022 9:20 pm
by Johanna
That looks good!
Posted: Sun Jul 17, 2022 8:16 pm
by Romainpek
I need your help again!
For my CPCL engine, when I disassembled the square drive shaft from the gearbox, 2 corroded washers came out.
And this is the top view of my gearbox, you can see where I replaced a new pin as the old one was totally chewed up.
in which order should I put back the 2 washers above? They are not shown in the blueprint I got from John, it seems on the drawings that the shaft is inserted directly on the gearbox stub, above the pin... I fear that one of them should actually be placed below the pin...
Posted: Sun Jul 24, 2022 9:55 am
by Romainpek
Hello to all,
Nobody knows the answer to my question above? I'm sure most of you have already separated the main drive shaft from the gearbox before!
