Page 4 of 8
Re: Unrestored 102 SD (Naval?)
Posted: Sun Jul 15, 2012 11:54 am
A measurement of the height of the flywheel centre may prove instructive.
Posted: Sun Jul 15, 2012 12:42 pm
Instructive? Height of flywheel this one (SD4726L3)is the same as my others within reach (SD6226L3 and SD9588L4) +/- 0.5mm.
Posted: Sun Jul 15, 2012 2:23 pm
by Beagle2
Thanks for all the replies everyone.
Crank measurements:
My top crank measurements come up slightly under? If they were the same the flywheel would sit even higher (!). However, I have seen differences between cranks before. I have a Century crank, which is approx 4mm shorter overall.
18.82 - 14.4
33.19 - 28.0
41.11 - 37.5
8.16 - 9.8
12.43 - 11.3
7.41 - 6.9
The lower measurements seem to be the same
6.31 - 6.4
34.76 - 34.1
Flywheel measurement
Slightly lower, between 45.1mm and 45.5mm
Oysters pics:
"These are my two SDs, plus a pic of one now sold. Quite a variation between the three" - yes quite a bit!
I forgot to mention my SD has no locating 'dimple'. If I move my base plate up a bit, it looks very similar to Oyster's first pic. I imagine I'll have to somehow set the timing manually?
I seed no evidence of the crank-case being machined / altered. My crank-case doesn't have "Seagull" cast into it, so I imagine it is an earlier version.
The washer seems a like a bit of an later bodge. The inner diameter doesn't match. Furthermore, it is uneven and wobbles when the base-plate is installed above.
I'm hoping that I just have a particularly 'high' sitting flywheel.
Posted: Sun Jul 15, 2012 2:40 pm
I meant the height of the one that has the washer - I'm wondering if the bashing around the rim may have flattened the dished top.
Posted: Sun Jul 15, 2012 3:08 pm
Well, lots of measuring above, who knows where it will sort out.
Classic questions and info this post..........love it
Posted: Sun Jul 15, 2012 4:13 pm
Looking at that crankcase casting, it does not seem quite "right" if you know what I mean. There are differences in the detail of the casting. Could you actually have a pre SD pair of crankcases there? This is a picture of a SD upper crankcase half, spot the differences? The lack of "Seagull" cast into the case is intriguing
Posted: Sun Jul 15, 2012 4:42 pm
by Beagle2
Hmmm. I don't know. Here are some more pictures. The cases certainly seem to match; maybe they were left over pre SD?
Maybe pre SD the crank was slightly different- hence con-rod bolts scraping on the inner crank-case?
Posted: Sun Jul 15, 2012 8:50 pm
There's another question for the SD registration form.
Posted: Sun Jul 15, 2012 9:16 pm
My SD is only about 300 away from yours, it is also an L3.
There is no seagull on the crankcae on mine.
Perhaps the 3 after the L means something, could be a different factory perhaps.
Does yours have the Skeg stamp?
Posted: Sun Jul 15, 2012 9:46 pm
by Beagle2
Hi, yes mine has a skeg stamp: "CIESS <- G 232", gearbox stamped 35, gearbox cover stamped 34.
I'm actually replacing this box with one from Oyster. The gear pinion was badly chipped
Posted: Sun Jul 15, 2012 9:52 pm
by Beagle2
charlesp wrote:I meant the height of the one that has the washer - I'm wondering if the bashing around the rim may have flattened the dished top.
Sorry Charles, missed your post. Height of flywheel center is 60.1mm
Posted: Sun Jul 15, 2012 11:53 pm
My early (125) also has seagull on the case.
Posted: Mon Jul 16, 2012 10:27 am
Is that a washer/spacer in that pic Huggy?
OR
Is it the split bush end.
There is a split bush in the casting of the backing plate, it can be moved in or out to maybe make a "Base Height adjustment"?
Just a thought.
Posted: Tue Jul 17, 2012 10:58 am
I Hear Silence
Posted: Wed Jul 18, 2012 2:09 am
No washer just the.....
BUSH......
