SD Register
Gilmore1
Re: SD Register
Post by Gilmore1 »
Aye Hugz .
Portside Nipples , OOO suits you Sir . Barrel not Painted , Standard Shaft , no Fuel Tap and the carb is bit of a mixture , Old style alloy float bowl Brass Top , later Jet Housing .
Eddie
Re: SD Register
Thanks for that. Unusual not having a painted barrel. Typically they are black or a zinc/gal finished. Wonder if it has been replaced?
Gilmore1
Re: SD Register
Post by Gilmore1 »
Yip , not a pick of paint on it , Drive Shaft tube is the same , no paint and in amazing condition for being almost 80 years old .
Eddie . That said now I've cleaned it up it may have a light Galvy coat on it , mostly bare metal .
Re: SD Register
That sounds likely. They would deteriorate quickly without an original coating. Amazing motors.
