Page 3 of 5
Re: Restoring a Marston OA
Posted: Sun Apr 29, 2018 8:37 pm
by JERSEYMAN
So good to see a serious restoration, brilliant thread.
Posted: Sun Apr 29, 2018 8:57 pm
Making a new HT lead, modern copper cored HT lead is now 7mm diameter and shiny PVC.
I use a bit of heat shrink to increase the size to about 0.34".
The larger size fits the old coil pickup, and heat shrink look more like the original rubber HT lead.
New solder on end, and good to go.
Posted: Sun Apr 29, 2018 9:47 pm
I'll make a sparky out of you yet!
Posted: Mon Apr 30, 2018 12:22 am
by AusAnzani
Very cool thread and workmanship!
Posted: Mon Apr 30, 2018 12:37 pm
The green spark plug co is a great supplier of all sorts of HT leads, connectors etc. should anybody be looking. They also do cloth wrapped HT leads.
http://www.gsparkplug.com/
Posted: Mon Apr 30, 2018 7:39 pm
Horsley-Anarak wrote:Will heat it up to get the end off, as it is a hard shape to hold to bore out, will come apart if I get it red hot.H-A
No it won't
Back to the lathe.
Posted: Mon Apr 30, 2018 8:15 pm
Oooops.....
Posted: Mon Apr 30, 2018 11:49 pm
Yikes, obviously not soldered or brazed then
Posted: Tue May 01, 2018 6:24 pm
Oyster 49 wrote:Yikes, obviously not soldered or brazed then
No it looks like it is brazed, just think some rust is holding it together.
Did not want to distort the angle bit, so will bore it out.
You can see the braze here.
Posted: Tue May 01, 2018 8:05 pm
Found out why It would not come apart, it was nailed together, with an iron nail.
So bored it out, made up an ali mandrel so I could use the tailstock to align it in the 4 jaw.
Nice to be able to see the braze when it is bored out.
Posted: Tue May 01, 2018 8:36 pm
Clever bit of packing
Posted: Tue May 01, 2018 9:04 pm
Oyster 49 wrote:Clever bit of packing
One of the packing pieces only cost 2p.
Posted: Wed May 02, 2018 7:24 pm
by JERSEYMAN
Did you know that pre 1992 2p and 1p are made of bronze making then worth 60% more than their face value....
Posted: Thu May 03, 2018 5:54 pm
Yes I had heard that, not sure my local scrapman would take them.
Posted: Thu May 03, 2018 7:29 pm
can make gifs on my new phone
