Upset century
Re: Upset century
Doesn't he say his problem is solved?
pat777
Re: Upset century
Post by pat777 »
I posted this on the previous page, but it may have been missed when page 3 opened.
Jon I can't find your new thread. If you can post a link to it please.
Thanks Charles,
Yes something very similar to SAE 30 but with less modern additives
So if not SAE 30, do you know a brand name of the 30 weight oil that I could look up please?
Re: Upset century
All of them have the additives nowadays Pat, & are probably the better for it.
pat777
Re: Upset century
Post by pat777 »
Thanks Charles.
British Seagull Outboard Motors
Manufacturers oil mix recommendations
Year of manufacture 1931-1978 (8:1 and 10:1 petrol:oil mix)
30 weight motor oil, SAE 30 modern equivalent.
sae 30.jpg (14.34 KiB) Viewed 2522 times
Year of manufacture 1978 and after (25:1 petrol:oil mix)
TCW3 2 cycle Marine oil
Re: Upset century
It's more complicated than that Pat as you've not included the non synthetic TCW2 & 3, 2-stroke oils of which the water cooled versions are good for the 10:1 Seagulls & all the later ones!
These are very low stress outboards hence their longevity, a little TLC as they get towards pension age wouldn't hurt.
I like oil it's a lot cheaper & easier to buy than pistons & cylinders!
red42hj
Re: Upset century
Post by red42hj »
My thread seems to have gone off on a tangent here with this interesting info on oils. I simply thought that others out there might find my progression through my problems, and its outcome, could help them with similar faults. When I searched the threads to find an answer; I found many recurring questions similar to mine. Unfortunately, very few results were documented.
It would be very helpful if problems that are resolved were posted.
Is my problem resolved? Not really, because I don't know the reason, and that is annoying. The engine is running now, but I have lost a lot of boat time meanwhile. Yes, I could have gone out and bought another engine to save time, but I've put a lot of time into this one, and now I know every square millimetre of it, and I'm not giving up on it. If I ever identify the problem I will post it. Thanks to all for your valuable input.
Red.
Re: Upset century
Fuel or ignition are the 2 most likely culprits here.
Now that you have a special "bond" with your gull it should be easier the next time around anything goes wrong.
Glad you got it sorted out in the end. Well done
