Page 3 of 4
Re: We have a Seagull Outboard
Posted: Fri Oct 16, 2015 5:14 pm
Nice to see more seagulls in Derbyshire!
Posted: Wed Oct 21, 2015 11:30 am
by awhitecat
Nice to hear from you, Oyster. They say that the village of Coton in the Elms , Derbyshire is the furtherest point from the sea in England. Sometimes Derby itself feels like it! I've been away with work the last few days, however I hope to have another look at my Seagull before the weekend. I still haven't purchased any oil for either the fuel/oil mix or the gear box. Do you know of anywhere in Derbyshire that sells these?
I have to think about a barrel or waterbutt to run this thing in soon.
Mike
Posted: Wed Oct 21, 2015 1:36 pm
A wheelie bin is always an option.
Wheelie Bin Test Bed
Posted: Wed Oct 21, 2015 5:48 pm
by awhitecat
Keith, I had thought about using our Wheelie Bin, however I had already seen this cartoon (on the Saving Old Seagulls Forum?)
There could be critism if I'm seen using the family Wheelie Bin for 'inappropriate purposes'!
Also I'm worried about our Wheelie-Bin being too high for me - picturing myself up a stepladder to get the motor in! I guess I'm looking for something like this
50 litre bins. Shall these enable the prop shaft etc to be deep enough in the water for testing?
Posted: Wed Oct 21, 2015 6:27 pm
They look a little short, the outboard skeg will keep the prop away from hitting the bottom of what ever you use, not the sides obviously.
Measure your outboard from skeg to thumb screws and that will give you an idea of depth, you can go shorter, but this will only make the motor more top heavy and unstable when starting.
Good old water buts. (test tanks)
Zimma frame. (outboard stand)
Posted: Wed Oct 21, 2015 10:07 pm
by awhitecat
Thank you for that advice, Keith. My apologies to whoever owns this photograph. I think this motor is similar to mine.
I have marked the position of the skeg and the thumbscrews (I think!). Would it be possible for somebody to mark the best depth of water?
Thank you.
Posted: Wed Oct 21, 2015 11:41 pm
Anything is possible.
looks right to me.
Too little water and the water pump will struggle, too deep and it may struggle to start, especially on older motors with low compression.
One of my motors that I have used on my boat, the water level is just below the transom bracket, so it will run deeper on the back of a boat, so no lower than the red line and you will be fine, as long as you are not using a bucket.
Posted: Fri Oct 23, 2015 7:21 pm
by awhitecat
Looking at my points
My photograph looks the same as photographs here. I am used to rotating an engine and seeing the points open and close. On this Seagull, that I cannot do this as the flywheel only lets lets you look through the hole at one point of the rotation. As you can see, my points are closed in this photograph. Everything looks clean and not corroded or dirty. I can put my finger in through the access hole and easily open and close the points. Inserting a screwdriver (incidentally there is quite a strong magnetic field inside - I presume this is good?) The Points Locking Screw undoes easily. When undone the Points Adjustment Screw does turn, albeit not so easily. As I turn it, I do not see the points open. Is it anti-clockwise or clockwise to open the gap?
Any suggestions would be appreciated.
Thank you, Mike.
Posted: Fri Oct 23, 2015 8:57 pm
Turning the flywheel clockwise or anti-clockwise it makes no odds, the cam that the points run on is the centre for the flywheel, removing the flywheel will give you better access, but you have to set the points with the flywheel on.
As you have played with the points, you will have to reset them, set the points at just open, as you are trying to find the highest point on the cam, that's when they are open, rotate the flywheel until you see the points gap either open more or close, once you find this, then you set the gap.
The points only open for a small part of the flywheel rotation, you can see it though one of the holes, go slow.
A barrel from a skip
Posted: Sun Oct 25, 2015 3:44 pm
by awhitecat
I spotted a barrel in a skip. It is now in my garden.
It is 40 cm diameter and 80 cm high. I guess that makes it a 100 litre odd barrel. I still think in terms of 44 gallon drums! I shall think about making some sort of frame for it to sit in/upon and on which I can mount the Seagull engine. I liked the welded square section trolley design that appears in the photograph I borrowed earlier in this thread. If anybody has photographs of suggested, easily made test mounts, I would appreciate them being posted. Thank you. I have wooden pallets! I do not have a welder - I'd like one!
I
think I have set the points to 20 thou. We shall see, I guess. I unscrewed the bowl on the bottom of the carburettor and it seemed very clean, so I screwed it back on. I did not check the small filter that Keith referred to earlier. It appears to be easily damaged.
I have to reinstall the fly-wheel and the fuel tank. I shall then reconnect the fuel line.
I have bought neither gear-box oil nor two-stroke oil yet. I was hoping that somebody might have posted a source in Derbyshire, however no luck yet. I shall probably order them online this week.
Thanks for the help here.
Posted: Sun Oct 25, 2015 4:27 pm
You don't need much more than a piece of wood in front of the thumb screws, like this.
Posted: Sun Oct 25, 2015 4:44 pm
by awhitecat
Thanks for that, Keith. Upon blowing up the photograph I can see what you mean. As you said about a wheelie bin, clamping to a square bin has to be easier!
Nice looking motor!
Mike
Posted: Sun Oct 25, 2015 8:07 pm
by awhitecat
Is there supposed to be a washer under the Domed Nut on top of the Flywheel Cover?
Thank you.
Posted: Sun Oct 25, 2015 9:11 pm
yes, it should have, I think it helps centre the cover, its pretty much the same as the old style set up, but in one piece of plastic.
My picture has a brass flywheel added, its not a seagull part.
Posted: Mon Oct 26, 2015 6:33 pm
by awhitecat
Well, I've ordered my oils and am looking for the washer that goes under the Domed Nut on top of the flywheel.
I've remounted the fuel tank, however I shan't connect the fuel line until I've washed out the tank with some fuel/oil mix - up until now, I've only used kerosine to wash out the tank.
I shall look at my test barrel and think about how to mount the engine.
I vaguely remember somebody talking here of taking the prop off before test running the Seagull in a barrel. Is this correct? If so, how do I remove the prop?
Thank you for the help.
