Page 3 of 4
Re: Evinrude 6hp 1981 (Belgian)
Posted: Tue Apr 10, 2012 9:51 am
by xtaffy2
Thanks HA. that was great link as it answered a load of question for me. Your a gem.
Geoff
Posted: Tue Apr 10, 2012 6:48 pm
Daryl wrote: Any chance of some nice clear pics like you have done, of a full view of the component side & one of the copper track side looking straight down on them?
Had my camera out today.
If these are not clear enough, let me know and I will have another go.
I have spoken to an OMC experts in the states, and he said a little slop in the big end bearings is normal, also the center main needles do run a little blue.
So I am now a little happier to replace the top needle, bottom ball race, and both of the seals.
He also said that if the crank or CD2 prove to be a problem, then he would send me a replacement.
There are nice people in the ouboard collecting world. :)
P.S. 5 is orange blue, 6 is black yellow, 7 is orange.
Posted: Wed Apr 11, 2012 12:25 am
by Daryl
Thanks for that HA.
Posted: Thu Apr 12, 2012 9:20 pm
It now sparks like a sparky thing should spark :D
Click on the picture and you will see a video of sparks.
Thanks Daryl, it is nice to make something work again, for an outlay of £2.50.
Posted: Fri Apr 13, 2012 10:30 am
by Daryl
Good one H-A, nothing like the satisfaction of fixing it.
Posted: Fri Apr 13, 2012 12:10 pm
Daryl do you have any views on the carbon composite resisters as don't they control the timing?
Posted: Fri Apr 13, 2012 1:16 pm
by Daryl
Hi Charles. Those old carbon resistors realy should be changed as they will probably off value by now, but it apears to be working. They have nothing to do with timing as the base plate with the triger coil is moved by the throttle linkage, advancing the timing as the throttle is opened.
Posted: Fri Apr 13, 2012 1:52 pm
They are obviously working but as there is at least one in each spark circuit & any change in resistance will change the timing of that circuit could this cause let's say, one plug to fire at 23 before & the other fire at 13 before when they're both expected to fire at 23 before with the baseplate in that throttle controlled position.
Don't most people replace these as a matter of course as after 30 years they could have changed their value by up to 100% or perhaps even gone open circuit.
Any carbon composite resister across the gate will over time, have increased in value delaying the gate release.
Posted: Fri Apr 13, 2012 2:11 pm
by Daryl
I will try & daw the circuit of this unit, will take awhile. The thing is probably very few people atempt to repair the modules, just that i like a chalenge to see if it can be done. H-A has done quite a reasonable job so far. Also are these modules still avalable new, or are they only avalable as new old stock or just 2hand modules. & at what price? Im of to bed soon as its getting late here.
Posted: Fri Apr 13, 2012 5:23 pm
Posted: Fri Apr 13, 2012 6:33 pm
Well I am glad it works, thanks Daryl for your help.
Electronics is not my area of expertise, but I am glad to have a go with advice and help
I have measured all the resistors that I identify, the largest error I can find is o.8%.
So as the magneto base moves about 45 degrees and flops about in use, I am not bothered.
If the engine does not run well I will invest in a new CDi, they are only £60, but I am glad I got this one sparking.
If you look hard enough at any project then potential faults can be found.
Personally I just get on with it, and do it.
Posted: Fri Apr 13, 2012 8:52 pm
As somebody with very electrical understanding all I can say is TOP JOB :D Very satisfying to get it going again.
Posted: Sat Apr 14, 2012 6:19 pm
Thanks Oyster.
Better still it runs :D
Click on picture to see video.
I thought it would be ok when it started up on WD40 when I was testing the recoil.
Will treat it to a new impellor.
Posted: Sat Apr 14, 2012 10:37 pm
by Taspiper
Nice little outboard that now HA! 8)
Posted: Sat Apr 21, 2012 10:54 pm
I ran it for 5 hours today on my local river, what a nice quiet engine.
It starts easily, smooth gear change, economical, does not smoke much, loads of power.
I have seen the OMC light, it performs and starts much better than my more modern Merc 4.
But I did take a seagull as a backup motor. :D
I am starting to see the benefit of twins.
