Page 3 of 5
Re: YASP - Series 90 failing to start
Posted: Fri Feb 18, 2011 5:14 pm
by gaffers
The carb:
The bowl is full after trying to start:
The float setup, note: the pin comes down properly:
This is the pin:
And finally the float:
Posted: Fri Feb 18, 2011 5:57 pm
Float retaining pin does not look like the correct one.
It looks a little under size, but this should not stop it from running.
Running out of answers ?
P.S. Picture of float bowl, main jet should not come off with float bowl. Main jet should be screwed into carb first then float bowl screwed onto jet.
Posted: Fri Feb 18, 2011 6:00 pm
by gaffers
Erm yes it is a temporary replacement for the pin which is at the bottom of the testing tank.
I had to replace it yesterday and it has had no effecton the operation of the float
Posted: Fri Feb 18, 2011 6:05 pm
by gaffers
Is the crankcase leak theory a valid one? If so I'll give it a go with the WD40....
I have a working villiers carb from a 40+, if I fit it to the 90 should it work? That way I could eliminate the carb as the issue (or not)
Posted: Fri Feb 18, 2011 6:25 pm
gaffers wrote:Is the crankcase leak theory a valid one?
Could well be, post some more pictures of the engine it may narrow it down a bit.
P.S. 40+ carb fits a 3/4" stub so will not fit a 90.
Posted: Fri Feb 18, 2011 6:40 pm
All 400 series carbs have the same size inlet holes in their castings, the same 416 body was used on all the seagull models up to the Osprey.
Posted: Fri Feb 18, 2011 6:50 pm
Charles
gaffers wrote:villiers carb
Posted: Fri Feb 18, 2011 6:59 pm
Whoops sorry!
Posted: Fri Feb 18, 2011 7:16 pm
by gaffers
Float, side on:
Float up:
The carb stamp:
Is that a 1b?
Posted: Fri Feb 18, 2011 7:31 pm
I've just found a 416 1 & mine is a pumped carb with a brass rubber tipped needle.
Can you post a pic with the float & needle removed so we can see the hole where the needle fits.
Posted: Fri Feb 18, 2011 7:49 pm
by gaffers
The amal carb has just told me that he intends to get an agent and charge a fee, and the 40+ is sulking in the corner and will not speak to me now........
.....or have I inhaled too many petrol fumes
Posted: Fri Feb 18, 2011 11:00 pm
What does YASP standfor? All I could find was Youth Alternative Sentencing Program. Though I guess EFNR's are relative youths compared to their older siblings.
Posted: Fri Feb 18, 2011 11:22 pm
by gaffers
Hugz wrote:What does YASP standfor?
Yet Another Starting Problem
Posted: Mon Feb 21, 2011 7:47 pm
by gaffers
Ok I am feeling a little bit sheepish that I did not notice this earlier. SWMBO demanded her bin back as it's collection day tomorrow so as i lifted the gull out and propped it up against my worktable I noticed this:
cant see it? Try a close up:
Here is where there must have been a 'blow':
Not sure if it came like this or if it has fallen off:
So I am guessing that the block and crankcase need to come apart and be cleaned before reassembly?
Posted: Mon Feb 21, 2011 8:18 pm
Could be
I was flushing my 102 this evening, and got the 1/4" bsf spanner to tighten the cylinder to crankshaft studs.
whilst washing it with a soapy brush around the crankcase cylinder joint, the engine speed picked up.
That could be why it was a little off colour yesterday Charles.
I have had a featherweigh, that whilst underway started making wheezing noises. That was the two bolts that bolt the cylinder on had come loose. It had got so bad that it stopped.
I always carry a couple of spanners in my pocket, I tightened up the two bolts and used the engine for the rest of the weeks holiday on the Norfolk broads with no problems.
In your case Gaffers I would try a 1/4 BSF nut on the stud, tighten them all up and you may find it is all OK.
