Page 3 of 3
Re: Beginners design and build
Posted: Tue Jul 13, 2010 8:52 pm
The Aussi version of Spadge is also interesting.
P.S.If you dont get the kilt hire bit, just google "Spadge Kilt Hire"
Posted: Tue Jul 13, 2010 9:29 pm
by outboard
Aha, mmmmmmmmmm, I've googled.
Posted: Thu Jul 15, 2010 8:40 pm
by outboard
Tidy, that is easy to follow.
Would it change things if I didn't have any sealed compartments, i.e. an open seat not boxed in like HA has done? I already suggested a bosun locker, actually I wasn't going to put a closed bit on it either, I was thinking of just a shelter for storing stuff out of the way but easily accessable? Might sound daft, why bother but it makes it different to others. This boat is only for fun not for long treks. But, if putting in sealed compartments with bottles and foam is best please tell me.
Got other stuff to ask but they'll wait till I get this part clear. Hope you don't mind me asking, I'd like to know what I'm doing and get a clear idea in my head before making the final drawings.
Gerard
ps how do you use a router ..............only joking!
Posted: Thu Jul 15, 2010 10:54 pm
A sealed compartment, can be a structure consisting of two pieces of thin ply.
In effect you are creating boxed structures at the ends of the boat.
If I remember my Structures lectures correctly, then weight for weight a boxed structure adds great strength for little additional weight.
If you have seats at the front and back of the boat then the addition of one ply component to each seat creates a closed compartment.
I would think that the most common failure of any small hull is running in to a solid object. In that case you would puncture the hull.
This puncture you could hope would be within the sealed compartment. The compartment would flood but the boat would not.
I personally will still build in compartments, then even in the worst case the boat will not dissapear without trace.
Posted: Sat Jul 17, 2010 9:44 am
by rosbullterier
'Pool Noodles' - (or should that read Poo Noodles)
Is that what's produced after consuming 'Pot Noodles' ?
Posted: Sat Jul 17, 2010 1:01 pm
Not got a swimming pool on that Fletcher then? RBT.
Posted: Sun Jul 18, 2010 11:39 am
by outboard
Manifold or HA, as I was trying to make a cardboard model I realised the transom was a bit tricky to measure, will this be the case using plywood. I assume the structure when stitched, will have a lot of sag and movement. Is there any software where the complete plans are printable, including the transom.
Posted: Sun Jul 18, 2010 3:12 pm
I think that there should be very little problem working out the size of the transom.
You know the width of the boards that will join it, so it is just simple school boy geometry to draw it out either to scale or full size.
Have just found this page that gives a good beginners guide to stitch and glue technique.
http://www.bateau2.com/howto/sg101.php
Worth a read.
I built a Bateau pram dinghy about 12 years ago, as my first boat.
Posted: Sun Jul 18, 2010 8:23 pm
by outboard
I'm sure you're right, just thought I'd ask. I saw with making a card model it was flimsy so just wondered what the real thing would be like.
I'm hoping others are getting good information from this thread to encourage them to design and build, that's why I'm asking questions to help us newbies to be ready for the big build.
Thanks
Posted: Sat Jul 24, 2010 10:56 pm
by outboard
When I was mentioning a bosun's locker type thing, I was thinking of something like the bow of the "Poole Canoe" as seen on Charles' thread, but not being closed, maybe a hatch inside where tools and stuff could be stored out the way.
